Any help on these matters are greatly appreciated!
So its a 1993 Ford Escort LX 5 Speed Manual.
When on the highway crusing at about 65-70 mph in final (5th) gear, it runs fine for about 2 minutes just crusing along, then it will start to sound like its starving for fuel all of the sudden and start hopping, over and over again, until you floor the pedal, in which case straitens out the hopping, but it still takes anywhere from 10-20 seconds to stop starving for fuel with the pedal floored.
Secondly, the other day I went to back out of my driveway, and hadnt taken my foot off the cluth at all, and the car began to back out of the driveway all by itself as if the cluth was only about half way depressed. In reality it was to the floor.
The funny thing about it all is the car runs fine in 1st, 2nd, 3rd, and 4th gear, but it hops in 5th, and winds like crazy in reverse.
Lastly, this kind of relates to the way it backed up in reverse with the cluth down to the floor, I think, but sometimes when I park in a parking spot, go inside of a store or whatnot, and come back out, I get in and start it up, and it wont want to come out of the gear I had it parked in, wheter it be 1st gear or reverse, and it acts like its wanting to pull, yet the cluth is to the floor.
One quick thing I wanted to add, is that I bought a Sunpro Super Tach II, to install on the escort, because whats the point in having a 5-speed with no rpm guage, thats crap, Ford did'nt add one on the Escorts around that year, which im sure you know. My question here is how do I install it, (What Wires Do I Soder and where are they located).
I read the directions that came with the tach, but the wire they specify to control the rpms on the tach (to move the needle), is (so they say) on the ignition control module for the 1993 Ford Escort, and the color they specify is NOT on the ignition control module. I went to there website and they say that on most fords you have to go for the (certian colored) wire on the engine computer rather then the ignition control module. I also need to know what wire for the backlight (in the dash somewhere), and of course, where would be best for the Positive 12V wire, and the Ground.
Once again, if you can help me with even one of these problems, it is GREATLY appreciated. Thank you.
Apr 16, 2020 at 11:53 AM
(Merged)
