1996 Ford Escort heater blowing cold air
1996 FORD ESCORT
NEWFY
  • 8 POSTS
Heater problem
1996 Ford Escort Front Wheel Drive Automatic 100,00 miles
I changed the thremostat and rad cap, I filled the rad with coolant, started the car with the rad cap off, it blew the coolant up out of the rad, Ihen refiled the rad and replaced the cap than start the car, the top rad hose became very hard and warm but no heat from the heater HELP.
Dec 1, 2007 at 9:28 PM
MERLIN2021
  • 17,250 POSTS
You did point the spring end of the thermostat towards the block right? Youll need to flush or replace the heater core.
Try warming the Vehicle, then carefully feel the heater hoses, are they both hot? If one is cooler than the other, You need to flush the core, or a replacement job on the heater core. Also if the system has a heat control valve on the heater hose, make sure it is working!
Dec 2, 2007 at 8:36 AM
