1996 Ford Escort Cold start surging, when coming down from
1996 FORD ESCORT
206,000 MILES • 4 CYL • FWD • AUTOMATIC
BACKYARDFORDGUY
  • 6 POSTS
when coming down from fast idle the rpm surges.I have check fuel pressure 31psi at idle 34psi at 2000rpm.I also checked the egr seals fine, mass air flow sensor voltage readings fall within spec, vacuum gauge reads 18 inches steady check for plugged cat seems fine on the vacuum gauge, I also notice at -20 cel the car is hard to start I have to hold my foot to the floor but it does start and run ok sometimes it does stall. This problem is only when it is cold when hot no surging. Any ideas??
Sep 5, 2010 at 12:00 AM
It sounds like a throttle position sensor or idle air control valve. Has the check engine light come on?
Sep 6, 2010 at 12:21 AM
BACKYARDFORDGUY
  • 6 POSTS
[quote:5f2f669ffc="Jacobandnickolas"]It sounds like a throttle position sensor or idle air control valve. Has the check engine light come on?[/quote:5f2f669ffc]
I have replaced the Idle Air Control Valve and no response, it only does it when cold. I am going to check for a plugged converter again, also when hot the rpm doesn't come down right away it slowly comes down to idle with no surge. I cleaned the intake with spray in cleaner and it seems to throttle better but still same problem. No engine check light yet.
Sep 7, 2010 at 1:56 PM
Let me know what you find with the converter.
Sep 8, 2010 at 7:03 AM
BACKYARDFORDGUY
  • 6 POSTS
Hi, Bob, Ken
I checked the vacuum again, I got, at a somewhat rough idle 18.5 in Hg to 19 in Hg. Then at 2500RPM was 20 in Hg it dropped under acceleration down to about 15 in Hg then recovered to 20 in Hg and held that reading without going up or down. So I think by this reading my converter is fine. I am trying to get a code reader to check if the check engine light came on then went out and stored a code. because no check light yet . I am leaning towards the throttle position or MAF but MAF resistance checks out within the normal range and resistance changes with no lag time.
Jeff
Sep 9, 2010 at 8:37 AM
If the maf reading are good, try cleaning it. They make a special cleaner that you can get at a parts store.
Let me know if that takes care of the problem.
Sep 9, 2010 at 9:37 PM
BACKYARDFORDGUY
  • 6 POSTS
[quote:053967196f="Jacobandnickolas"]If the maf reading are good, try cleaning it. They make a special cleaner that you can get at a parts store.
Joe[/quote:053967196f]
I cleaned the maf sensor no change. I managed to get another code reader. still no codes, but, I cannot get the o2 sensor heated o2 sensor monitors and cat monitor to run. I managed to get all the rest to say done on the code reader. Why is the monitors not running I am using the drive mode set by ford.
Jeff
Sep 13, 2010 at 5:41 PM
The only thing I can think of is a wiring problem or the PCM may need reflashed or is damaged.
Sep 14, 2010 at 7:18 AM
BACKYARDFORDGUY
  • 6 POSTS
[quote:1211cf2edf="Jacobandnickolas"]The only thing I can think of is a wiring problem or the PCM may need reflashed or is damaged.[/quote:1211cf2edf]
I was able to have all the monitors check in and run and done. No codes at all, but I did notice the car runs very smooth now. I think when I had the o2 sensors, idle air control valve changed awhile ago the PCM was not cleared properly. So I do not know if that will make any difference or not, maybe it will not allow the PCM to return to it's original fuel tables. Any ideas???
Sep 14, 2010 at 4:35 PM
That could be the case. Let me know if things change.
Sep 14, 2010 at 8:18 PM
BACKYARDFORDGUY
  • 6 POSTS
[quote:ae1e48bb85="Jacobandnickolas"]That could be the case. Let me know if things change.[/quote:ae1e48bb85]
Thanks I will let you know if things change. I have to drive the car again. Thanks alot for your help. It`s not easy some times working with this obdII computer cars....
Sep 16, 2010 at 11:25 AM
