1994 Ford Escort Transmission leak
1994 FORD ESCORT
89,950 MILES • 4 CYL • FWD • AUTOMATIC
SHAOLIN_DRAGON
On my Escort wagon, I recently had my rear pump seal fixed as it was leaking. Now the issue I'm having is that there is a small black rubber hose with a brass plug in it, located towards the front of the cars underside, and this is leaking transmissino fluid. Fluid is coming from the end of this rubber hose, even though there is a plug in it. So I have a two part question. What is this rubber hose piece, and why would it be leaking transmission fluid. How can i stop it leaking? The brass plug is not hollow, but a solid piece. Any help would be appreciated.
Aug 13, 2009 at 7:17 AM
LAZYGAZER
  • 68 POSTS
Hi if im not wrong this hose is the transmission vent this hose is usually supported by a plastic clip next to the refill/dipstick tube so it should be above the t/m not below it. It was probably moved during your repair and not put back in place
Your donation is greatly appreciated.
Aug 19, 2009 at 5:31 PM
