1994 Ford Escort starter wont stop and other problem
1994 FORD ESCORT
11,000 MILES • 4 CYL • FWD • AUTOMATIC
BRADCUSTER
the other day my wife started the car and the starter kept turning. i had to take the battery cables off because the starter keeps turning over even with key off. i started the car and unplugged the black small wire from starter to be able to get it home and when i turned off the car with the starter wire off i also noticed the cooling fan stays running key off as well concstantly it does not shut off. Also when this happened my fuel cutoff light came on and while i drove home it made the car run really rough like no power and i could barely get up to 55. any help with this would be greatly appreciated i have never seen this before. thank you for your time, brad custer.
Oct 29, 2008 at 1:49 PM
Posted: Wed Oct 29, 2008 12:49 pm Post subject: 1994 Ford Escort starter wont stop and other problem
I've been here before-if it continues to crank engine bang hard on the starter relay if it stops replace it-its sticking
Oct 29, 2008 at 2:12 PM
