1994 Ford Escort Security system locked
1994 FORD ESCORT
LIZ FLINTHAM
Electrical problem
1994 Ford Escort
I recently purchased a 1994 Ford Escort as a family run-around but last week it did not want to start when I turned the ignition key. A friend went to push-start the car but as a result the security system immediately locked and I am now unable to start the car at all. Have no idea what to do to sort this problem myself.Any simple solution please?
Mar 29, 2009 at 11:42 PM
BMRFIXIT
  • 19,053 POSTS
Check battery and battery terminal
remove and clean terminals
try and get a jump start
suspect a bad starter
or a solenoid
Mar 30, 2009 at 6:42 AM
LIZ FLINTHAM
Thanks for your reply. Hands up, I'm a woman - divorced and never had to do this for myself before. I don't think it is the battery that is a problem as the lights work ok (but that is about all that works)! I will try to check out what you suggested, but what on earth is a solenoid?
Mar 30, 2009 at 7:32 AM
BMRFIXIT
  • 19,053 POSTS
suggest have a helper and a test light
IF THE BATTERY IS GOOD
SUSPECT A BAD STARTER
if lights radio wipers all work and no starter check
starter
Mar 30, 2009 at 7:48 PM
