1994 Ford Escort leakind coolent
1994 FORD ESCORT
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
ARTHURS2206323
my car seems to be leaking coolent from between the tranny and motor. the car was ran low on coolent but it wasnt empty. i cant see any frost plugs that are bad and the block around the head gasket look fairly dry. I am stumped. i am at the point of pulling the head of but dont want to go any farther. i also have the water pump exposed and it doesnt appear to be leaking from there, and it is a pretty good flow that is coming out. please help
May 11, 2009 at 1:21 AM
BMRFIXIT
  • 19,053 POSTS
Pulling the head !!
if the leak is between the engine and tranny inside the bell housing
and no leak on top I would think its a freeze plug behind the flywheel and would pull out the tranny and or engine
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 11, 2009 at 6:01 AM
