1994 Ford Escort How do I drain the radiator fluid
1994 FORD ESCORT
DONNANAZ
Engine Cooling problem
1994 Ford Escort 4 cyl 90000 miles
I want to flush out the radiator - where is the plug to drain it located?
Where would I put the jack under the front of the car to raise it up?
May 17, 2008 at 12:23 PM
BMRFIXIT
  • 19,053 POSTS
if you cannot locate it at the bottom of the radiator remove the lower radiator hose
jack and stands should be mid side of car bit behind the front tire
May 17, 2008 at 5:49 PM
