1994 Ford Escort engine oil
1994 FORD ESCORT
50 PENCE74
Engine Mechanical problem
1994 Ford Escort Two Wheel Drive Manual 50000 miles
i accidently poured about 500ml of water into the engine oil tank this morning. could anyone please tell me what to do.
thank you
Jun 3, 2010 at 11:46 AM
BLACKOP555
  • 10,386 POSTS
change the oil and the filter. if you want then you can put new oil in it and run it for a little bit then drain taht too or use a engine flush product and put in fresh oil was it ran after you put the water in? if not then just drain the old oil and put new oil in
Jun 4, 2010 at 6:54 PM
