Engine Mechanical problem
1994 Ford Escort 4 cyl 260000 miles
I have to replace the timing belt, camshaft, cam seal, & 8 hydraulic valve lifters. Are there any parts inside the head or any other specific parts I need to replace assuming everything else appears to check out okay? I also assume I the head gasket now needs to be replaced since we pulled the head to get the camshaft out.
Oct 13, 2009 at 10:12 PM
