1993 Ford Escort starting
1993 FORD ESCORT
20,000 MILES • 4 CYL • 2WD • MANUAL
RORYO2358
some one stole my radio, i replaced it and now my car won't start. won't crank, light work, radio works until you turn key then radio stops restarts. can hear fuel pump lights will remain on when key is turned but nothing from starter. Fuel cutoff switch is down, thougnt it might be neutral safety switch but, when removed and bypassed still no action. any help will be appreciated.
Nov 12, 2008 at 12:53 PM
ZACKMAN
  • 4,202 POSTS
I believe the events are coincidental.
Check your fuse box under the hood. There is a fusable link marked C110. Make sure that it is still good. If it is, tap your starter with a soft mallet, and then try starting it. I have a feeling that it is your starter.
Nov 12, 2008 at 9:24 PM
