heater core
1993 FORD ESCORT
TRINI1962
ok i did all that you said but the frame for the instrumental panel is in the way so i can't get to pull out the black casing that contains the heater core , how do i get pass the frame could you reply with a diagram on how to get pass the frame?
4 cyl All Wheel Drive Automatic 76,600 miles
Nov 29, 2009 at 9:15 AM
Here are the directions and a picture of the heater core / box. 1. Disconnect the negative battery cable. If equipped, disable the SRS system. 2. Drain the cooling system. 3. Disconnect the heater hoses at the firewall. 4. Remove the instrument panel. 5. Disconnect the mode selector and temperature control cables from the cams and retaining clips.
https://www.2carpros.com/forum/automotive_pictures/249084_yoyo_2.jpg
Fig. 1: Exploded view of the heater core mounting-1991-95 models 6. Remove the necessary defroster duct screws and loosen the capscrew that secures the heater-to-blower clamp. 7. Remove the three heater unit mounting nuts and disconnect the antenna lead from the retaining clip. 8. Remove the heater unit. 9. Remove the insulator and the four brace capscrews. 10. Remove the brace. 11. Remove the heater core from the heater unit.
Nov 30, 2009 at 12:24 AM
