1993 Ford Escort fuel
1993 FORD ESCORT
128,000 MILES • 4 CYL • FWD • AUTOMATIC
AHOFFKIN
I have a 1993 ford escort I had to replace the fuel pump. After replacing the fuel pump along with fuel filter when I take a right turn the car starts to sputter like it is out of gas this did not do this before the fuel pump broke. I have used a fuel system cleaner, I also replaced the fuel pressure regulator but it still does this only when right hand turns are made when I take my foot of the gas for a few seconds it goes back to running normal but if I keep my foot on the gas when it is doing this the car will stall
Mar 26, 2009 at 12:43 PM
SERVICE WRITER
  • 9,123 POSTS
Check the fuel pressure with a gauge when the symptom is happening. I have seen issues with wiring going to the the fuel pump on these as well.
Tape the gauge to the windsheild so you can monitor.
Mar 26, 2009 at 5:52 PM
