I have a 1993 1.9l with automatic transmission. Car has approx. 134,000 miles. My transmission has quit working. When I first crank it it will work for a short period of time. Seems to pull fine and shift fine and then quits. After a few minutes it will work again. It does seem to be worse that when it first started. I have had other automatic transmissions that went out on me and they usually seem to slip a lot before they actually quite. My Escort doesn't really seem to slip it just quits.
Was wondering if I should just assume the transmission is bad and go that route (ie, replace transmission) or are there some electronic components that might be causing this to happen?
Dec 3, 2006 at 6:01 AM
