Engine Mechanical problem
1992 Ford Escort 6 cyl Front Wheel Drive Manual
I got the timing belt on (replaced) without getting the crankshaft bolt that holds on the guard and sprocket off. My question is what is the easiest way to time the engine? I can see the timing lines on the top two sprockets but not the crankshaft sprocket, i have tried running the sprocket around in a trial and error method and still no luck. Please help. Thanks
Nov 14, 2008 at 12:10 PM
