1992 Ford Escort parking brake warning light
1992 FORD ESCORT
138,000 MILES • 4 CYL • 2WD • MANUAL
BADNEWZ
I have an 1992 Ford escort LXE. When the vehicle is in park or when I am driving the park brake warning light stays on. I try adjusting the part brake cable itself but the light stays on. However, I did notice the when the hand brake is down the warning light becomes dimmer.
Jun 17, 2009 at 2:06 PM
BATMAN3124
I had the same problem with my 91 escort and found that it was because I was low on break fluid.
Jun 20, 2009 at 3:55 PM
BADNEWZ
thanks for you answer but the brake fluid is good in the vehicle. Its just the right side that failed the brake test here in Germany and the light v=stays on as well.
Jun 20, 2009 at 10:51 PM
