1992 Ford Escort Front Wheel bearing
1992 FORD ESCORT
20,700 MILES • 4 CYL • 2WD • MANUAL
777999YES
I want to grease my front wheel bearings,,I have the proper socket for the large nut to remove it,,,but it does not seem to move,,seems there is a small indention keeping the large nut from moving,,is it a stop to prevent the large nut from moving? how can I remove this large nut and get to the bearing. Thanks , Richard
Sep 16, 2009 at 5:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
To remove wheel bearing you must remove the hub & steering knuckle assembly. Procedures are below..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_975.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_272.jpg
Sep 16, 2009 at 9:11 PM
777999YES
THANKS VERY MUCH,,I THOUGHT THIS COMPUTER HAD SOME IMPORTANT PEOPLE USING IT,,,I WILL NOW GO TO WORK ON MY LITTLE CAR,,THANKS AGAIN AND AGAIN,,,,IF YOU NEED ANY INFO EITHER ON THE BIBLE OR ELECTRIC OR PLUMBING QUESTIONS,,,I WILL HELP YOU WITH ANSWERS,,,BLESSINGS TO YOU ALL,,RICHARD ---209-887-3524--
Sep 17, 2009 at 10:41 AM
