1991 Ford Escort lights
1991 FORD ESCORT
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
ARANMAN
in my Ford Escort Wagon 1.9l (petrol, automatic), my parking lights turn on and my full beams work but my low beams don't. also the reverse lights don't work.
can u help plesase
m
Aug 12, 2010 at 12:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did the reverse lights stop the same time the low beams stopped working? if not, most likely the back up switch is faulty for the reverse lights and the headlamp relay is bad for the low beams. first to check is the fuses though.
Aug 13, 2010 at 12:58 AM
ARANMAN
where are the fuses for the lights (headlights and reverse)?
where is the relay switch for the headlights?
where is the backup switch for the reverse lights?
thank you
Sep 3, 2010 at 1:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuse #2 (30 amp) labeled HEAD in the underhood fuse block. also fuse #3 (80 amp) labeled MAIN in the underhood fuse block if 1.8L equipped. headlamp relay is behind left side of the instrument panel. back up switch is on the transaxle.
Sep 3, 2010 at 2:00 PM
