My car quit, checked and no fuel to carb.
Checked with test light and no power seems to be
getting to the pump. There are four wires going to
the fuel tank, 2 are grounds, colored black, one is yellow, I believe that is the fuel gauge wire, it blinks with a test light on it and the fuel gauge still works.
The other wire is pink w/black stripe. No power in this wire with the ignition switch on. I checked the fuel pump shut off switch, it is okay. My chilton book on page 5-16 under fuel system/fuel pump diagnosis says "check fuse integrity" what fuse??? there is no fuse designated for the fuel pump in any of my books for this car. I located the fuel pump relay under the dash, is this the fuse they speak of? Is there a fuse link somewhere I can check, I am stumped. Can you point me where or what I need to do?
Apr 3, 2009 at 2:47 PM
