XLT model FI DOHC.
No symptoms as of yet other than the fact the check engine light came on.
After checking with Pep Boys was told it was the purge valve.
So initially attempted replacing the canister purge valve with this part: Duralast PV691.
No change in check engine light after a few weeks. And still no symptoms other than the check engine light still being on.
Went back to Pep Boys and am being told it is the canister valve solenoid.
I asked about the engine code this time and the reading showed: P0446.
I also asked for a specific part number this time and was told CVS20.
After doing some searching I found the part they mentioned: Standard Motor Products CVS20 (roughly $50.00).
After doing a little more searching I believe this is another equivalent: Duralast PV516 (roughly $100.00).
I believe either of these parts would fit my vehicle and do not see any difference other than the manufacturer.
I find it interesting that the Duralast is pretty much double the cost of the Standard Motor Products.
I went ahead and purchased the CVS20 part by Standard Motor Products.
I got under my vehicle and after much searching I believe I found the part. I was able to remove the electrical plug. I then was able to rotate the canister purge valve but any attempt to pull it up was unsuccessful so I am not sure how to remove it. My vehicle is not lifted so I do not have much headroom to work with and cannot even see the part as I am attempting to remove it. I confirmed it was the right part before doing anything by taking a video on my cellphone and positively identifying the part. Also, this video proved helpful in also confirming I found the correct part as it is in the exact location described in the video:
https://www.youtube.com/watch?v=g1uBZXtYy0Q
Please let me know if you recommend having it done by a professional mechanic or if you could let me know how the part is removed so that I could continue my DIY attempt.
Also, any other tips or suggestions would be more than welcome. Thanks in advance!
Sep 19, 2018 at 4:06 PM
