Trunk problem
2009 FORD ESCAPE
60,688 MILES • 3.0L • V6 • 2WD • AUTOMATIC
GIGISULAMANIDZE1
  • 88 POSTS
Hi, I have problems with trunk. i changed door lock, does not work. still it wont open.
Dec 4, 2017 at 11:55 AM
MHPAUTOS
  • 31,937 POSTS
use a screw driver shaft and press down on the lock to see if it is actually locking and releasing, if this is the case, look at the lock and striker plate alignment and make sure that the boot (trunk) lid is actually closing far enough for the striler to hit the lock at trigger it, look at this first.
Dec 4, 2017 at 6:09 PM
GIGISULAMANIDZE1
  • 88 POSTS
I am sorry trunk locks fine but it will not open. changed lock it opens once in day. i changed two locks, but still unlocks trunk in once a day.
Dec 4, 2017 at 10:30 PM
MHPAUTOS
  • 31,937 POSTS
Sounds like an adjustment problem, make sure that the lid is not closing down to far into the lock, you should be able to ease the lid down onto the lock and push gently to trigger the lock. if this is not happening it will probably mean adjustment problem or an alignment problem with the lid itself.
Dec 5, 2017 at 3:50 AM
GIGISULAMANIDZE1
  • 88 POSTS
Also, when trunk is open and i push the button in first push it has sound and moves the lock, but when i push second time lock does not have sound and it did not move.
Dec 5, 2017 at 4:00 AM
MHPAUTOS
  • 31,937 POSTS
Check the power at the lock solenoid when you press the button, if power is there each time, the problem will probably be a faulty lock solenoid.
Dec 5, 2017 at 4:09 AM
GIGISULAMANIDZE1
  • 88 POSTS
There are two connectors. in first connector when i press button there are twelve volts in voltmeter, but in second connector nothing.
Dec 5, 2017 at 4:17 AM
MHPAUTOS
  • 31,937 POSTS
The other if black will probably be a ground.
Dec 5, 2017 at 4:46 AM
GIGISULAMANIDZE1
  • 88 POSTS
I installed new solenoid but still does not work. it opens one time. :/
Dec 5, 2017 at 4:49 AM
It sounds like you have a problem with the smart junction box SJB. This is what controls the trunk release. Here is a wiring diagram of the SJB so you can see. Also I have included the location of the unit. A shop or the dealer will need to program it for you.
SJB location (below)
Dec 7, 2017 at 7:16 PM
