cabin air filter location
2009 FORD ESCAPE
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
ITTLFLY
I want to R&R the cabin air filter on my wife's Escape Limited. Can you advise its exact location and the best way to go about doing the job?
Thanks
Jun 4, 2010 at 6:47 PM
A cabin air filter is available for this vehicle as a dealer installed accessory. The accessory cabin air filter will be located in the air inlet under the RH side of the cowl panel grille, if installed.
Jun 4, 2010 at 6:52 PM
CRAZE8TS
Interior problem
2008 Ford Escape 6 cyl Four Wheel Drive Automatic 21k miles
Where is the cabin air filter located in a 2008 ford escape limited? Is it easy to locate and change?
Jun 25, 2020 at 7:26 PM (Merged)
CABIN AIR FILTER
https://www.2carpros.com/forum/automotive_pictures/12900_caf_1.jpg
Removal and Installation 1. Remove the RH cowl panel grille. 2. Remove the 2 water shield screws and the water shield. 3. Remove the cabin air filter. 4. To install, reverse the removal procedure.
ESCAPE2008
I looked under the hood, and loosened the cowling near the windshield, but did not locate the cabin air filter. Did I miss it?
The car always smells inside when we run the AC, I have to find the cause and either fix it or have it fixed. Since I'm recently laid off, I'd rather fix it myself!
DOCFIXIT
  • 18,828 POSTS
See diagrams
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_83.jpg
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_20.jpg
NOTE: starting in 2007 filter was dealer potion and may not be on your car.
JLS33941
2008 ford escape hybrid Cabin Air Filter location?
BMRFIXIT
  • 19,053 POSTS
Remove the 2 wiper pivot arm nuts.
Remove the LH and RH wiper pivot arms.
Remove 8 cowl panel grille pin-type retainers.
Remove 8 cowl panel grille caps and screws.
Remove RH cowl panel grille.
To install, reverse removal procedure.
Adjust wiper pivot arms. Tighten pivot arm nuts
CABIN AIR FILTER
Removal & Installation
Remove the 2 wiper pivot arm nuts. See Fig. 1.
Fig. 1: Cowl Panel Grille & Wiper Pivot Arms
Courtesy of FORD MOTOR CO.
Remove RH cowl panel grille. See Fig. 2.
Fig. 2: Water Shield & Cabin Air Filter
To install, reverse removal procedure. Adjust wiper pivot arms. Tighten pivot arm nuts to 26 lb.ft. (35 N.m
ELIDELAPAZ
I can't find cabin air filter location
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1514.jpg
FIG.1
https://www.2carpros.com/forum/automotive_pictures/261618_1_105.jpg
FIG.2
https://www.2carpros.com/forum/automotive_pictures/261618_2_80.jpg
ANDREWS
is there a cabin air filter that can be changed and where is it?
DAVE H
  • 13,384 POSTS
REMOVAL & INSTALLATION NOTE:Manufacturer's terminology for this filter is cabin air filter or passenger compartment air filter. CABIN AIR FILTER Removal & Installation Remove the 2 wiper pivot arm nuts. See Fig. 1. Fig. 1: Cowl Panel Grille & Wiper Pivot Arms Courtesy of FORD MOTOR CO. Remove the LH and RH wiper pivot arms. Remove 8 cowl panel grille pin-type retainers. Remove 8 cowl panel grille caps and screws. Remove RH cowl panel grille. See Fig. 2. Fig. 2: Water Shield & Cabin Air Filter Courtesy of FORD MOTOR CO. Remove the 2 water shield screws and the water shield. Remove the cabin air filter. To install, reverse removal procedure. Adjust wiper pivot arms. Tighten pivot arm nuts to 26 lb.ft. (35 N.m).
https://www.2carpros.com/forum/automotive_pictures/266999_gril_1.jpg
https://www.2carpros.com/forum/automotive_pictures/266999_gril2_1.jpg
