2008 Ford Escape Car is dead
2008 FORD ESCAPE
1,000 MILES • 4 CYL • AWD • AUTOMATIC
MONTREAL_GUY
Hi guys hope you can help,
I started my 2 month old Ford Escape last night with the remote car starter which was installed by Ford when I purchased the vehicule. 5 minutes later I opemned the door to get into the car as usual and everything shut off. I can't even start the car with the key in the ignition. The key turn but nothing happens. The automatic doors won't even function. It seems the car is just dead or on some sort of lockdown. Does any one have any clue on what it might be ?
Thanks your help !
Giulio
Jan 1, 2009 at 11:50 AM
DAVE H
  • 13,384 POSTS
have you checked the battery and battery connections .. also the connections to the remote starter ?
Jan 1, 2009 at 12:01 PM
MONTREAL_GUY
Hi Thanks for the reply,
I checked the battery connections and it seems fine.
Jan 1, 2009 at 12:07 PM
DAVE H
  • 13,384 POSTS
check the connections to remote starter and all the main fuses in underhood fuse/relay box midi pink 125A fuse and fuse 27 in underdash (below centre)junction box
Jan 1, 2009 at 12:20 PM
MONTREAL_GUY
Thanks for the help it ended up being a loose batteryconnections I don't know if it's because of the starter installations or factory defect. I will bring it to Ford on Monday after the holidays. Thanks for the help and have a happe New Year!
Jan 1, 2009 at 2:32 PM
