This guide will show you how with diagrams and instructions below to show you how on your car. The filter is internal just fluid is the service
Specifications
General Specifications
Item .................... Specification
Fluid
Motorcraft MERCON Multi-Purpose (ATF) Transmission Fluid XT -2- QDX .................... MERCON
Fluid Capacity
All .................... 9.6L (10.2 quarts)(3)
Lubricant
Multi-Purpose Grease XG-4 .................... ESB-M1C93-B
Sealant
Thread Sealant with PTFE TA-24 .................... WSK-M2G350-A2
(3) Indicates only approximate dry-fill capacity. Some applications may vary based on cooler size and if equipped with an in-tank cooler. The amount of transmission fluid and fluid level should be set by the indication on the dipstick's normal operating range.
Feb 7, 2009 at 12:24 AM
