transmission problem code p0705
2003 FORD ESCAPE
193,555 MILES • 3.0L • V6 • 2WD • AUTOMATIC
GIGISULAMANIDZE1
  • 88 POSTS
hello, vehicle is four wheel drive. when i drive car at highway or city at 50-70 mph and i release foot from gas pedal it shifts at third gear and when i press gas pedal again it shifts fourth gear. no check engine light. i plugged scanner and found DTC p0705 Transmission Range Sensor Circuit Malfunction.
Can it be the reason of the problem?
Jun 17, 2019 at 2:13 AM
Good morning,
The range sensor tells the PCM which gear you have selected for driving. No, it does not have anything to do with the issue.
https://www.2carpros.com/articles/automatic-transmission-problems
I would start by changing the fluid and filter. The dirty fluid will cause this issue as it will inhibit valve movement in the valve body.
Jun 17, 2019 at 2:50 AM
GIGISULAMANIDZE1
  • 88 POSTS
i will change oil. i add oil about month ago (not OEM oil) and then it started shifting like that. oil level is good.
Jun 17, 2019 at 2:59 AM
Yes. change the oil and see what happens.
Jun 17, 2019 at 3:19 AM
GIGISULAMANIDZE1
  • 88 POSTS
hello, i changed fluid and filter but nothing has changed, still shifts bad, also when i speed up it wont shift into gear properly and then it jerks and shifts.
Jul 20, 2019 at 8:19 AM
Okay, then it has an internal failure in the transmission.
You will need either a rebuilt unit or a used unit installed.
Jul 20, 2019 at 10:36 AM
