2003 Ford Escape 2003 Ford Escape Shakes at greater than 40
2003 FORD ESCAPE
107,000 MILES • 6 CYL • 4WD • AUTOMATIC
FORDESCAPE3357
2003 Ford Escape (4x4, V6) The engine runs smooth and is a perfect car as long as your speed is under 40 mph. Once over 40 mph it begins to shake. The feeling does not come through the steering wheel so much as it does the whole car. At 50 mph & up the shaking increases. I have had it to 2 mechanics & have had the following completed.
1 Placed new tires on the front of the car. All the tires were aligned. The second mechanic alligned the tires (shaking continued)
2 The ABS light came on and half of the axle was changed out to fix that problem. But the shaking continued.
3 The first mechanic sent it to a tranmission specialist and they said the tranmission was in great shape.
4 The first mechanic changed out drive shaft (used) under warranty I purcahased and the problem did not stop.
5 The second mechanic felt it may be the carrier barring and the warranty company sent another used drive shaft to replace the first one put in.
6 Next on the list is motor mount ? Any suggestions?
Feb 15, 2010 at 11:03 AM
MCARTHUR6262
After you get above 55 mph you said that it gets worse or does it seem to stop.
Feb 17, 2010 at 7:23 AM
FORDESCAPE3357
It continues to shake at 55 to 70 mph. I put two additional new tires on the car and did very little to stop the shaking. All the tires are new and have been balanced again. Ford pointed to the two tires as the problem. Not the case.
Feb 24, 2010 at 5:54 PM
