I have a 2002 ford escape using a lot oil no leaks . whats going in the motor
Nov 7, 2009 at 11:19 PM
CERTIFIED EXPERT
If its not leaking internally could be burning in the cylinders and at the same time you'll be seeing blue smoke on the back, is this the case. If so could be valves and rings problem and cylinder wear.
