2002 Ford Escape Power Door Locks only work with key turned
2002 FORD ESCAPE
BEEZMW
Electrical problem
2002 Ford Escape 6 cyl Four Wheel Drive Automatic 85k miles
I'm partially overhauling my Escape after it was stored inside for 3 years... Currently the power door locks only work with the key turned, possible related problems is the radio doesn't work at all, nor do the interior lights. Checked the door lock, radio. and all related fuses in the kick panel, and the wiring seems to be in check.
Is there a battery direct power relay I need to check? Could it be a faulty ignition switch?
Oct 1, 2009 at 1:09 PM
ADAMBRAM
[quote:655290047c="beezmw"]Electrical problem
Is there a battery direct power relay I need to check? Could it be a faulty ignition switch?[/quote:655290047c]
Did you ever figure out what was wrong with your Escape? I am having the same problem. Mine is a 2002 Ford Escape. I just had a battery installed, and now I have all of the same problems you did. If you know what it is, could you please email me at [email protected]. Thanks!
-Adam
Dec 8, 2009 at 3:19 PM
