The ABS are kicking in when they are not supposed to. They check them and are 35% used and work fine.
They notice that the RPM was not going back to idle normally. You push it at 3-4K and then release the gas, the RPM does not comback to idle normally. Its take like 2 seconds and could even reincrease a little bit and then go below 1K. Once idle, the engine run fine.
The computer does not report any problems and has been reprogrammed. The garage suggested to replace the computer.
Note: I did not go to a Ford dealer.
Mar 5, 2010 at 8:27 AM
