2002 Ford Escape FUEL PRESSURE
2002 FORD ESCAPE
BEN DONLEY
Engine Performance problem
2002 Ford Escape 6 cyl Four Wheel Drive Automatic
HAS 68 PSI. NEEDS 39-55 DOGGY PERFORMANCE COMPARED TO IDENTICAL MODEL. HAS NEW FILTER AND FUEL DAMPNER.
Oct 27, 2008 at 10:55 AM
TECHMAN1
  • 82 POSTS
This may help you and it may not. First of all, run the engine at night and see if either the front or rear exhaust manifold glows red.
Each exhaust manifold has a 4 inch by 6 inch "flash off converter". These are filled with a steel wool like substance. I had one blow the guts out of it downstream and plug off the inlet to the primary catalitic converter. You can unbolt the inlet side of your catalitic converter, look into it with a flashlight, and see if the engine runs better with it open. Looking into the inlet of the primary catalitic converter, you should see only a ceramic honeycomb.
Nov 12, 2008 at 6:00 PM
