2002 Ford Escape EGR flow excessive
2002 FORD ESCAPE
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARDS1805
My 2002 Ford Escape's check engine light just won't go away. The code is P0402 EGR Flow Excessive. When I went to Auto Zone they gave me a list of things to change so I did. Changed all the vaccuum lines I could see, replaced the EGR valve, replaced the EGR sensor, replaced the EGR vaccuum solenoid, and now here I am with my light still on. I noticed a slight high pitched humming noise when the vehicle is on and when I accelerate it hums louder with the engine. Please help me if you could.
Apr 8, 2010 at 11:13 AM
Are you sure the valve is closing? If you remove the vacuum to it, does the code change?
May 4, 2010 at 11:20 AM
CARDS1805
It has to it is a brand new EGR valve.
May 4, 2010 at 5:25 PM
