2002 Ford Escape A/C
2002 FORD ESCAPE
COXFAMILY0801
Air Conditioning problem
2002 Ford Escape
My 2002 Escape is intermittenly blowing extremely hot air, like the heat is on, when the A/C is turned on. I have taken my car to a repair shop and had the compressor replaced twice, orifice tube replaced twice, condenser replaced three times, and clutch cycling switch and receiver dryer replaced once. The dealer now has my car and can't find anything wrong. The A/C works fine in the mornings. In the afternoon, it blows out heat. I can cut it off and on but it will continue to blow heat each time. In the morning after it's sat all night, it works. Any idea what could be wrong?
Jul 21, 2010 at 11:42 AM
If it is blowing heat and not just outside air, there is a problem with the blend air door. It determines if you get AC or heat. Have him check that.
Let me know what you find.
Aug 24, 2010 at 10:11 PM
