2001 Ford Escape thump
2001 FORD ESCAPE
13,500 MILES • 6 CYL • 4WD • AUTOMATIC
PACSTER
whenever it hits a bump i hear a thump,sounds like its coming from front end.my mechanic has replaced both struts and right front axel and still have the same problem.any suggestions?
Oct 8, 2008 at 10:22 AM
2CARPRO JACK
  • 11,533 POSTS
sway bar end links..... could also be the strut tops (mounts)
Oct 8, 2008 at 7:47 PM
RACEFAN966
  • 5,029 POSTS
Has the strut turn plates or mounting plates been replaced? The other thought is maybe the sway bar endlinks or bar to frame bushings. If there is a strut rod it could be the bushing on it. I have those checked and see where that leads you. Thanks and hope this helps
