2001 Ford Escape rough idle
2001 FORD ESCAPE
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
NATE265
when cold engine has trouble idling, must put in neutral and give gas to keep it idling. once engine is warm engine runs normally
Jan 28, 2008 at 7:46 PM
BLACKOP555
  • 10,386 POSTS
Sounds to me like a faulty coolant temperature sensor to me. usually the #1 cause of the problem you described. and usually goes away when worm.
Jan 28, 2008 at 8:28 PM
TODDZ2000
I changed to air idle control unit. That did help, but it was still idling low at times.
Then I had the throttle decarb and PVC replaced, still a problem.
I'm taking back to service station.
Jan 31, 2008 at 9:30 AM
