Hi I have a Escape 2004 v6 4wd 3,0l , same pinout pcm connector ( 104 pin )...In this tread you have posted here with 8 picture , is this diagram for 2wd is aplicable to my escape 2004 4wd ? Or we have to find a new one specialy aplicable for the 2004 version ... I need more explanation on this aspect about those diagram please?
Concerning my case , i have taking the first step to begin to check the '' Ground Wire '' of the motor and pcm , to be sure of all good connection . My truck have been shooted with oil since the beginning , but some loose or broken wire can induce some intermittent problem with misfire in accelaration ... Something shure presently i have some intermittent noise pickup over the air on weak radio station on the AM band . I have all ready change the antenna kit . same result ... When the truck was newer no noise was present...
Thank you
Aug 15, 2022 at 8:43 AM
