The condition of the diaphragm inside the booster is also important. If cracked, ruptured or leaking, it won't hold vacuum and can't provide much power assist. Leaks in the master cylinder can allow brake fluid to be siphoned into the booster, accelerating the demise of the diaphragm. So if there's brake fluid inside the vacuum hose, it's a good indication the master cylinder is leaking and needs to be rebuilt or replaced. Wetness around the back of the master cylinder would be another clue to this kind of problem.
To check the vacuum booster, pump the brake pedal with the engine off until you've bled off all the vacuum from the unit. Then hold the pedal down and start the engine. You should feel the pedal depress slightly as engine vacuum enters the booster and pulls on the diaphragm. No change? Then check the vacuum hose connection and engine vacuum. If okay, the problem is in the booster and the booster needs to be replaced
Aug 28, 2009 at 7:58 PM
