This is called the inertia switch and I am attaching the info below and is used to cut the fuel off in the event of an accident or rollover.
However, I suspect you have an issue with fuel pressure or the engine not starting. If you do then here is a guide that will help with checking it to be sure:
Take a look at the info below on this switch and how to replace it.
Please let us know what questions you have. Thanks
Nov 9, 2021 at 7:03 PM
