2001 Ford Escape Engine Misfires and Runs rough
2001 FORD ESCAPE
151,000 MILES • 6 CYL • 4WD • AUTOMATIC
ARCHMEDIC
  • 11 POSTS
I have been trying for some time to get my '01 Escape to run smoothly - I have been having problems with poor acceleration, loss of power, rough idle, and rough running for quite a while. My check engine light has been coming on, showing codes in pairs - either misfire in cylinder 1 and 5, 3 and 4, or 2 and 6. Nothing that I do seems to keep it from misfiring.
In my efforts (in part to fix the problem, and also just as a tune-up), I have replaced: Spark Plugs, Upper and lower intake manifold gaskets, Idle Air control, Fuel Filter, Throttle Position Sensor, DFPE sensor, EGR valve, air filter, all 6 COP, fuel injector O rings, battery (which was dead) and the Camshaft Position Sensor.
I checked the MAF (it is a hot wire) - it is spotless, but I tried to clean it as well. No improvement. Cleaned the throttle body just for good measure, but couldn't find any significant blockage or deposits.
I also tried some fuel system cleaner with not much improvement - I took it down to the injectors and swapped a couple of them out to see if the misfire moved with them. It didn't - I still got the same codes. While I was down there, inspected the manifold and gaskets but didn't notice anything out of the ordinary.
I have looked for a vacuum leak, but was unable to find any - as far as I can see the hoses, etc are in good shape. Possible I missed something.
All of this work has resulted in some improvements - i.e. it idles better, accelerates better, has some more power, etc than it did. Still getting the CEL, still feels like it is running rough, still a lot of vibration and still a loss of power, especially just after it shifts up into the next gear on acceleration. Still has poor fuel economy also.
One of the reasons that it has taken me so long to diagnose this is that every time I replaced a part, I disconnected the battery, and for a couple of days it would run better. Then it would start running badly, and the CEL would come back on. I thought I finally had the right solution about a dozen times. Just recently realized that disconnecting the battery was resetting something in the computer. One time I got codes PO302 and PO306, disconnected the battery, reconnected it, and a day later got codes PO301 and PO305 - without doing anything else to the car.
After that, I replaced all 4 O2 sensors (150K, and I don't believe that they have ever been replaced). That was yesterday - took the car for a drive today. CEL has not come on, but when I accelerated the car skipped - almost like something either missed, hesitated, or misfired in the car. It feels better, but still has a hard time accelerating after it shifts up into the next gear - almost like it is shifting too early or something.
I'm afraid that I still haven't fixed the problem, and hoping to get it licked for once and for all. So any answers that might help me do that would be greatly appreciated. I have recently got an computer scan tool (AutoEnginuity)- I can read and monitor the codes and some live data streams if that would be of any use. If there is any other information that would be helpful or testing procedures that you would recommend, please let me know. I know this is a lot of verbiage, but I figure the more information the better.
Jan 1, 2010 at 2:41 PM
MATHIASO
  • 1,209 POSTS
HELLO ArchMedic The random misfire DTC indicates multiple cylinders are misfiring or the PCM cannot identify which cylinder is misfiring. you did replace what we call the most likely causes of the problem such as such as DFPE sensor, DPEVR(differential pressure EGR vacuum regulator) Next is to check the camshaft position sensor,it could cause similar problem.then you have a faulty catalytic as a potential candidate. Beside that you have the fuel pressure sensor as a second candidate to cause that problem. This can help to locate the components (check your email )
https://www.2carpros.com/forum/automotive_pictures/46384_dpevr_1.jpg
https://www.2carpros.com/forum/automotive_pictures/46384_camshaft_1.jpg
Jan 1, 2010 at 5:26 PM
ARCHMEDIC
  • 11 POSTS
I was hoping you could clarify your response. As I mentioned, I have already replaced the camshaft position sensor. I am reluctant to go ahead and replace the catalytic converters, as there are multiple converters and the two just off the engine are both expensive and a royal pain to access.
The fuel rail pressure/temperature sensor however, shouldn't be too big of a problem, but I am unable to find any information about it. None of the usual resources that I check have any info about it. Is this usually a dealer only part? Do you have any further info about the location, or the part number or manufacturer, or where I could find such a thing? Thanks!
Mar 21, 2010 at 9:16 PM
MATHIASO
  • 1,209 POSTS
all codes point to vacuum leak or a weak pump or pcm problem.
If you have a scan tool, look at the Short Term Fuel Trim (STFT) and Long Term Fuel Trim (LTFT) values. Normal range is plus or minus 8. If the numbers are +10 or higher for STFT and LTFT, the engine is running LEAN. If you rev the engine to 1500 to 2000 rpm and hold it for a minute or so, and the STFT value drops back down to a more normal reading, it confirms the engine has a vacuum leak at idle. If the STFT value does not change much, the lean fuel condition is more likely a fuel delivery
problem (weak fuel pump than a vacuum leak.)
From there we see which way to go.
Do not replace any parts yet.
Get back to me as soon as you find something.
Mar 22, 2010 at 8:26 AM
ARCHMEDIC
  • 11 POSTS
Between when I asked the first question and my follow-up I had already replaced both the fuel injectors and the fuel pump (with a used one) - believing it was a weak fuel delivery problem. The following are screen shots from several of the times that the CEL came on.
https://www.2carpros.com/forum/automotive_pictures/169479_2CP1_29DEC09_1.jpg
https://www.2carpros.com/forum/automotive_pictures/169479_2CP2_06MAR10_1.jpg
https://www.2carpros.com/forum/automotive_pictures/169479_2CP3_22MAR10_1.jpg
Hopefully they will help. I did not do the test that you suggested because the first thing that I noticed when I hooked up the scanner was the STFT was below 8 (as in the last capture). I can still try it if necessary, just let me know.
Mar 25, 2010 at 10:29 PM
MATHIASO
  • 1,209 POSTS
Thank you for the screen shots
have the ignition module tested at an automotive repair shop then get back to me.
Mar 26, 2010 at 12:57 AM
ARCHMEDIC
  • 11 POSTS
There is no "ignition module" on this vehicle. There is also no distributor - according to the Haynes manual, the ignition system consists of the PCM, Crankshaft sensor, camshaft sensor, spark plugs, COP, and that's pretty much it. It says that "the functions of the ignition control module are incorporated into the PCM." And before you ask, yes - I already replaced the Crankshaft sensor.
What else could it be?
Apr 1, 2010 at 5:16 PM
MATHIASO
  • 1,209 POSTS
Check the vacuum lines that are wrapped in heat protective coverings. They tend to fall apart internally but you cant see it. With vehicle idling, move the vacuum lines around and see if it changes the idle. Have seen this on many Fords
Apr 1, 2010 at 6:21 PM
MJACOBY
I had almost the same issue. I have a 2001 Escape with 154,000. My vehicle would run really rough and misfire, especially worse when it would rain or snow. I took my vehicle to a mechanic several times and he had no idea what was going on with it. I spent several hundred dollars and the issue was not fixed. He just said you must have bad gas or something. I kept driving on it for some time and one day my EGR valve blew out and my vehicle was inoperable. My catalytic converter was glogged up to the point the pressure blew out the EGR. I took my vehicle to a Ford Dealership and spent $2,000 to have them run the diagnostics on it and fix the problem. I had 2 coil packs that were bad and a few seals needed replaced. The coil pack itself wasn't bad, just the rubber boot, but I didn't realize at that time just the boot could be replaced by itself. It had cracks in it and moisture was leaking in. Several months later I had the same symptoms return and after scanning the check engine light, I found another coil pack had went out. Replaced it with a new one and that fixed my problems. No issues. Just wish I would have spent the 2 grand in the first place.
May 6, 2010 at 12:19 PM
ARCHMEDIC
  • 11 POSTS
mjacoby - Replacing all 6 coil packs was one of the first things that I did.
mathiaso -
I took my car to a mechanic and asked him to check it out and let me know what he thought was causing the problems described. It continues to sputter, jerk, and hesitate - even popping from the rear when we start it up in the morning. The CEL continues to read Cylinder misfire. The mechanic did a cylinder leak-down test and told me that cylinder's 1,2 and 6 had a greater than 20% compression loss, and that he believed that the leakage was not just at the valves but also through the piston rings. He suggested a refurbished engine to the tune of $4,000.
Although I have no reason to distrust this mans word, I have a hard time believing it is such a serious problem, when it is so intermittent and I still seem to get a significant improvement in the performance just by unhooking the battery and re-setting the system. Further, I discussed this with a second mechanic and he told me he would hardly ever trust a cylinder leak-down test as they are not reliable at all - but with this many miles on the engine it could definitely be a mechanical failure.
Further research (on this site among others) suggests that it may indeed be the valves as the popping sound is characteristic of bad valves. I am also loosing some anti-freeze (very slowly) - I've had to add more twice over the last 3 months. But no, I haven't had anyone test the ignition transformer yet.
My question would be - is this a likely scenario? Could bad valves/rings/head gasket be causing all the problems that I describe and lead to cylinder misfire? Or is it still more likely that one of the other cause previously mentioned is the culprit? (Fuel rail pressure regulator, catalytic converter, ignition transformer, PCM, etc)
May 21, 2010 at 4:49 PM
MATHIASO
  • 1,209 POSTS
Hello ArchMedic
A loss of 20% compression in cylinder's 1,2 and 6 could make the engine running 80% on 3 cylinders and 100% on the others 3 cylinders in your 6 cylinder's engine, causing misfire.
when compression is lower in one or more cylinders, then the valves or the rings are suspect.
A wet compression test is useful in deciding whether rings or valves are the problem.
if compression comes up during the wet compression test, then the rings are most likely the problem.Conversely ,if compression does not comes up then leaking valves are the likely problem.
A leak-down test is more precise and pinpoint what the problem is.
If air is heard escaping from the exhaust,then you have a leaking exhaust valve.
If air is heard escaping from the intake,then you have a leaking intake valve.
If air escapes and causes bubbles in the radiator, the head gasket or cracked head is the problem.
If air comes from the pcv valve,leaking ring is indicated.
The popping noise you mentioned is coming from the catalytic converter, because of the misfire, unburned fuel enter the exhaust and ignites in the converter.
The most likely is leaky exhaust valve
that has been allowing unburned fuel to enter the exhaust system.
A real cylinder leak-down test must be perform to make sure the problem is only the valves or the rings,because it is expensive repair and there is no room for guessing.
May 22, 2010 at 1:57 AM
ARCHMEDIC
  • 11 POSTS
I understand what you are saying, and plan first thing next week to take it to a dealership for a leak-down test if I cannot get to it myself.
I do have one more question - you mentioned that the popping sound is the unburned fuel escaping into the exhaust and burning at the catalytic converter. I understand this can happen because I had a BMW with a dead spark plug that had this exact problem.
The confusion that I have is because when the Ford "pops" it is right when I start it up in the morning. After not running it all night, and the catalytic converter cold enough to hold in my hand is precisely when I get the MOST popping sounds. Usually it goes away after the car gets warm, later in the day. Generally it happens within the first 10 seconds of start-up, so how could the cat be hot enough to be igniting unburnt fuel? Is there some other explanation?
May 22, 2010 at 7:28 PM
MATHIASO
  • 1,209 POSTS
When engine get cool,the aluminum head relax,that is the time where any liquid make there move, either through valve guide, or oil rings or head gasket. a mix of coolant or a mix of oil with fuel causes misfire when engine start for few seconds in the morning.
When engine get hot, the head expands and that help seal little bit the leak but compression will still be loss .
consider the popping noise as thunder and lightning.
when you see the lightning it takes few seconds before you hear the thunder.
if you disconnect the exhaust from the engine, you better have hear plugs on when you start the engine because you will find out where the sound originate.
Have a leak down test done so we can find out the exact location of the problem
May 22, 2010 at 8:36 PM
ARCHMEDIC
  • 11 POSTS
Before I could get to the cylinder leak-down test, I got a compression tester to check the compression myself, to verify what has been told me. The results are below:
Dry: Wet:
1- 170 175
2- 160 160
3- 170 180
4- 160 170
5- 160 165
6- 160 170
There is some variation, but I'm skeptical that these results would warrant a teardown and rebuild of the engine. If there was a problem with any of the cylinders, no matter where it was, wouldn't it show up here? These seem pretty solid results to me, don't you think - on a 9 year old Ford with 165K?
I also did a vacuum test a couple weeks ago and got great results - very steady reading, no fluctuation. Should I maybe be looking in another direction entirely, or is a cylinder leak-down test still needed?
May 31, 2010 at 7:11 PM
MATHIASO
  • 1,209 POSTS
Hello ArchMedic
No change in compression with a wet test regarding #2 tell me the problem is valve related (probably a bad exhaust valve) or a blown head gasket.
Have a leak down test done so we can continue.
May 31, 2010 at 9:58 PM
ARCHMEDIC
  • 11 POSTS
I have still been unable to get my Escape working correctly. I have been to another repair shop, where they diagnosed it with an manifold air leak, replaced the spark plugs and re-assembled it with liquid gasket sealant and declared it fixed. It ran well for about 3 days, and then the CEL came back on and the problems started all over again.
Now, however, I am getting a different CEL code - P0401. I haven't been getting the misfire code in some time (maybe that was the spark plugs - I had platinum 2). The P0401 code is for "Insufficient EGR flow." But I have already replaced the EGR valve, and the EGR vacuum solenoid, and the EGR Delta Pressure feedback sensor. When I apply manually apply vacuum to the EGR valve, the engine stumbles and almost stalls. I can feel a vacuum at the input to the solenoid switch, and all the lines look good. I can feel a week flow (less than 1 psi) at the input for the DFPE sensor (at idle). What could be causing this code to set? Is there any other way that I can test this system, or any part of it?
Aug 7, 2010 at 9:25 PM
MCSGARAGE
  • 12 POSTS
I also just worked on same vehicle. Clogged converter! It is caused by cylinder misfire, typically from wore out spark plugs. the misfire in return ruins the converter.
Dec 5, 2010 at 12:17 AM
MOPARPA
Hi mcsgarage
Which catalytic did you chance? Their is 3 on them.
I have an 01 Escape with 213k miles and have 2 bad coils and have rough and misfire and no power most of the time, bad when rain/snowing. I know the coil/plugs need changed and don't know if the cat is bad also. Sometimes I get P0420 catalyst system efficiency for bank 1, and always misfire on cylinder 2 and 5.
Thanks
Jun 6, 2011 at 3:19 AM
ARCHMEDIC
  • 11 POSTS
moparpa
While changing the O2 sensors on my escape did nothing for me, I did eventually figure it out. I had purchased some knock-off coil packs, and they were just not up to the task. Eventually a dealership figured it out. I bit the bullet and bought 6 new coil packs, OEM this time. It is now 8 months since I've had to touch the engine (aside from oil changes). No CEL, no misfires whatsoever. I would go with the coil/spark plugs first, and see how it does before moving on to more complicated matters.
Also, just a tip - if you have an Advanced Auto parts store nearby, go online and find a discount code. Make a purchase online with the code - and just select local store pickup. You get the same part at the local store, but with a discount. I did it with the coil packs and saved 30-40 percent.
Jun 8, 2011 at 1:03 PM
KHLOW2008
  • 41,814 POSTS
Some non OEM components just are not up to the mark and it can kill as we tend to overlook them once we have thenm replaced.
When things don't work out as they should, getting back to the basics is the only way to root out the cause.
Feb 11, 2012 at 6:15 AM
JCHAMMOCK
After a month of changing sensors and chasing computer codes, mine was a clogged catalytic converter, specifically the bottom one. A mechanic advised me to disconnect the crossover that connects the two manifolds underneath and start the engine. Yes, it is loud, but if the engine runs right when you do this, the lower cat is your problem.
Apr 9, 2012 at 4:30 PM
MERLIN2021
  • 17,250 POSTS
The v sic also had seberal PCM updates for rough idles and misfires, along with poor shift quality, see if any apply to yours.
Apr 10, 2012 at 3:46 PM
JR2001
So which cat did you replace?
Jun 30, 2014 at 1:53 PM
JR2001
So is that the rear cat one?
Jun 30, 2014 at 1:57 PM
CHUCK26885
did you go to school for being a mechanic? if so how can a burnt valve or head gasket not show up when doing a dry virus wet test? alos if you check these pressures 160-175 or 180 they would be in normal range telling you the problem is not internal.
Aug 10, 2014 at 1:14 PM
