engine over heating
FORD E-SERIES VAN
AQUARIUSMAN
I have a 1994 Ford E 150 econoline conversion van
noticed its over heating how can I tell before taking it to a repair shop if its thje water pump, or the thermostate is stuck, or clugged radiator, may be the fan clutch???
Aug 11, 2007 at 10:18 AM
[quote:8a9a94bcb1="aquariusman"]I have a 1994 Ford E 150 econoline conversion van
noticed its over heating how can I tell before taking it to a repair shop if its thje water pump, or the thermostate is stuck, or clugged radiator, may be the fan clutch???[/quote:8a9a94bcb1]
Try changing the thermostat for a start. If it continues comeback.
Aug 11, 2007 at 3:41 PM
HLPOST
Have a Ford E150 with 126,000 miles no problems until now Did a tune up a few days ago and now the engine over heated. Changed the Thermostat forund a leak, when removing the inside cowel water running out around the rear right cylinder head. Does not appear to be comming from the head just to many hoses to be able to find the leak. Any suggestions. It did throw a code P1299 and the engine injectors dropped out for colling the head. Is there a colling hose diagram out there I could find to trace the leak
Thanks
Aug 21, 2007 at 11:33 AM
