Hello saul juarez
it was good idea to check the fuel line and I suppose you did not fine any leak.your next move is to make sure The fuel injectors do not leak: Clean or replace fuel injectors.
Wrong ignition timing could also cause that problem, or a faulty gas cap. recheck the fuel line fittings.those are more likely to leak.
May 1, 2010 at 9:17 AM
