2005 Ford E-Series Van The Air Conditioner will not shut do
2005 FORD E-SERIES VAN
146,116 MILES • V8 • 2WD • AUTOMATIC
RMARREROJR
The Air Conditioner on the Van will not turn off when I leave it n but turn the car off at its key. I have to turn the A/C off at ts switch so it will then turn off. What is wrong? It used to turn off OK when I shut the car down...
Jan 1, 2009 at 11:21 AM
BILLYMAC
  • 2,204 POSTS
sounds like a typical power distribution box prob this is the fuse box you should have it checked by a dealer. they will typically go bad and cause strange elec problems such as lights not comeing on or going off switches staying powered on 12v instead of accessory. good luck billymac
Jan 12, 2009 at 8:37 AM
