Engine Mechanical problem
2004 Ford E-Series Van Two Wheel Drive Automatic 130000 miles
I have 04 ford E350 extended w/v-10
130000 miles. about 8 months ago at about 115000 it became very difficult to fill with gas. fill pump cuts off different all the time. sometimes cuts off after 50 cents sometimes $2. no matter what gas station or whatever way you hold pump handle. clicks off n gas usually spills on ground. I ve removed tank 3 xs. Fill tube and breather clear from obstruction. float in tank looks good but i removed the internal part that floats to top and presses membrain over hole. (i was desperate) still needs to fill exceptionally slow or spills or kicks off. single 30 gal ish tank. local dealer lost.
Thanks, Dan
Thanks, Dan
Aug 5, 2009 at 10:02 AM
