2002 Ford E-Series Van o2 sensor
2002 FORD E-SERIES VAN
140,000 MILES • V8 • 2WD • AUTOMATIC
my 2002 ford e150 runs extremely rough on a cold engine. After warming up, it does quite a bit better, but still a little rough. Check engine light is on, and O'reilly's says it is the code for 02 sensor. Should I trust this as being the o2sensor? If so, how easy is it to fget to; I think they said it was bank 1. Thank you!!
Aug 28, 2010 at 9:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
A failed oxygen sensor will rarely cause a rough idle issue, although a clogged catalytic converter will cause this issue and will also throw the oxygen sensor trouble code. I would suggest having the cat. converter flow tested as well as replacing the oxygen sensors. They are part of regular maintenance anyway and are not difficult to replace.
Aug 28, 2010 at 11:46 AM
