turn signal flasher/hazard flasher
2001 FORD E-SERIES VAN
107,021 MILES • 6 CYL • 2WD • AUTOMATIC
DPC
where is the turn signal flasher located on a 2001 e-250 ford van? the turn signals and the emergency flashers will flash once or twice and then stop.
Mar 15, 2009 at 8:53 PM
DAVE H
  • 13,384 POSTS
It is kind of tucked up and out of the way on the drivers side dash, here is a diagram to help find it.
https://www.2carpros.com/forum/automotive_pictures/266999_e1_1.jpg
Please get back to me with any additional information.
Mar 15, 2009 at 9:44 PM
REF_JIMH
where is the four way flasher switch located
Jan 19, 2017 at 2:42 AM (Merged)
The electronic flasher is located behind left side of dash. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
MELJ
When you drop the turn signal all the way down the flasher is very fast and does not work, if you hold it down to the first detent it will work ok, but this is harder to do in a turn, etc. The bulbs have been replaced and the right side works fine.
FREEMBA
  • 1,152 POSTS
The turn signal switch is most likely faulty. they have a lot of plastic parts and sometimes they break and will not stay in the detent area on its own. You'll have to replace the switch to correct the problem.
MELJ
It will stay in the detent but when there it flashes as if the bulb is out.
PSD444
Electrical problem V8 Two Wheel Drive Automatic 205000 miles
Where is the hazard flasher located on my 1997 ford e150 van? I found the turn signal flasher but cannot for the life of me find the hazard flasher.
Sep 10, 2019 at 4:56 PM (Merged)
The flasher for the hazards and the blinkers are the same unit under the dash on the drivers side here is a diagram (Below) that shows the location for you.
