Honestly I've never done this year/model on the 4.2L below is the removal process
REMOVAL
WARNING:
DO NOT SMOKE OR CARRY LIGHTED TOBACCO OR OPEN FLAME OF ANY TYPE WHEN WORKING ON OR NEAR ANY FUEL-RELATED COMPONENTS. HIGHLY FLAMMABLE MIXTURES ARE ALWAYS PRESENT AND MAY BE IGNITED. FAILURE TO FOLLOW THESE INSTRUCTIONS MAY RESULT IN PERSONAL INJURY.
FUEL IN THE FUEL SYSTEM REMAINS UNDER HIGH PRESSURE EVEN WHEN THE ENGINE IS NOT RUNNING. BEFORE WORKING ON OR DISCONNECTING ANY OF THE FUEL LINES OR FUEL SYSTEM COMPONENTS, THE FUEL SYSTEM PRESSURE MUST BE RELIEVED. FAILURE TO FOLLOW THESE INSTRUCTIONS MAY RESULT IN PERSONAL INJURY.
CAUTION: After disconnecting, plug the fuel lines to prevent leakage.
Remove the engine cover.
Remove the air cleaner assembly.
Relieve the fuel pressure.
Remove the upper intake manifold. For additional information, refer to Engine.
Remove the fuel pressure regulator valve vacuum hose.
Disconnect the fuel lines.
Disconnect the six fuel injector electrical connectors. NOTE: One fuel injector is shown, all are similar.
Remove the fuel injection supply manifold.
Remove the bolts.
Remove the six fuel injector retaining clips and the fuel injectors. Inspect the fuel injector O-rings and if necessary, install new. CAUTION: The fuel injectors are deposit-resistant. Do not clean. Use O-rings made of special fuel resistant material. Use of ordinary O-rings can cause the fuel system to leak.
INSTALLATION
To install, reverse the removal procedure. CAUTION: The injector clips must engage the upper groove on the injectors or fuel leaks may occur. NOTE: Lubricate the new O-rings with clean engine oil, XO-10W30-QSP or DSP or equivalent meeting Ford specification WSS-M2C153-G, to aid installation.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jun 18, 2010 at 9:46 PM
