1998 Ford E-Series Van Error CODE PO305 and PO306
1998 FORD E-SERIES VAN
224,000 MILES • 6 CYL • 2WD • AUTOMATIC
NEVANS2600
I'm getting both error codes for misfire on 5 and 6. I believe the misfires happen around 40 mph. The van shudders around that speed. I've had a complete tune up done on the ignition system. What else could be causing the error codes.
Mar 1, 2009 at 5:55 PM
Check 5/6 sparkplugs, compression and injector
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Mar 1, 2009 at 6:02 PM
NEVANS2600
plugs are fine and compression is good. How do I check the injectors? Thanks.
Mar 1, 2009 at 7:07 PM
Check the fuel injectors resistances and do a fuel pressure drop on each injector
Mar 1, 2009 at 7:18 PM
