I am trying to reach the EGR Valve to replace it. What is the easiest way to get access to the mounting bolts?
Aug 8, 2008 at 6:24 PM
MASTERTECHTIM
CERTIFIED EXPERT
can i ask why you are replacing it?
Aug 8, 2008 at 6:45 PM
BADABBOTT
MEMBER
The check engine light is on and the code read EGR problem.
I have been experiencing all the problems associated with a bad valve and cannont pass emissions w/o its replacement.
My van is actually a 1996, '98 is a typo.
Aug 8, 2008 at 8:20 PM
MASTERTECHTIM
CERTIFIED EXPERT
99 percent of the time the problem is not the valve but in fact the sensor that detects valve operation. this sensor (dpfe) takes about 5 minutes to replace. its held in by 2 8mm bolts and has two fat rubber hoses going to it. it usually gives a code 401 or 402. low flow or too much flow. try this first then get back to me if it does not fix the problem.
