1998 Ford E-Series Van Blinker, break and emergency flasher
1998 FORD E-SERIES VAN
DAVIDLYNCH
Electrical problem
1998 Ford E-Series Van Two Wheel Drive Automatic 190000 miles
My front and rear blinkers, break lignts and emergency flashers do work. fuses are good. Is there a common component that is likley the problem? I have heard that there may be a "flasher" module but I'm not sure where it is located on the Ford Club wagon.
Mar 6, 2010 at 8:31 AM
The one common element is that they all get power through the same wire. If I was to start, I would check for power to that wire. Check each socket to see if there is a problem with the socket. If there is nothing there, work backwards until you find where the power is lost.
May 4, 2010 at 8:57 AM
