1994 Ford E-Series Van replacing the heater core
1994 FORD E-SERIES VAN
KTHOMMEN
Engine Cooling problem
1994 Ford E-Series Van V8 Two Wheel Drive Automatic
Luckily I see I can replace the heater core from the passenger interior side of the van without removing to many things. What I can't seem to figure out is how to disconnect the hoses from the heater core. My Chiton's manual indicates I need to use tool T85T-18539-AH to remove the hoses. What exactly does the tool do and is it possible for me to make the repair without the tool?
Aug 4, 2009 at 10:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
You will indeed need to use the special service tool T85T-18539-AH to disengage the heater hoses. This tool is a quick disconnect tool, similar to those used for some fuel lines. It releases the quick connects on the heater hose ends to allow you to slide the hose off. There is no other way to remove the hose without causing damage.
Aug 4, 2009 at 11:26 AM
