I have a van that has a miss. Starts up fine all the time but when I plug in the MAF Sensor I hear clicking sounds and it runs very rough. When I unlug the sensor the idle smooths out but has no power. WHen I remove the positive cable it resets the computer codes and then it will run fine for about 4o miles then the code must come back. I replavced the sensor. I had a local garage replace the injectors and they replaced them with used ones and the problem it still there. Where do the three wires go to from the sensor plug? This may help me trace them down. Thank you
May 22, 2010 at 8:14 PM
